Revit MEP Forum
Importing into Revit
3 REPLIES 3
brane1012
421 Views, 3 Replies
Hi!
I am MEP designer from Croatia using REVIT. I have a problem that most of our equipment manufacturers provide us only with 3D CAD blocks and I realized that REVIT doesn’t like importing 3D CAD blocks.
I am curious is there any other way of importing CAD blocks – What about exporting them first to the .SAT file and then importing into REVIT to create the family?! Does Revit work any faster using that method?!
Best regards, Branimir Segotic
3 REPLIES 3
CoreyDaun
in reply to: brane1012
I don't have much of an answer for you, but I believe you can import the 3D CAD into a Family first, and then load that Family into Revit.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
brane1012
Any other suggestions??
thombrady
Yes, there are multiple websites offering Families. You can try this link (http://www.revitforum.org/mep-family-creation/98-manufacturers-providing-revit-mep-families.html) or just go to autodesk seek. Also if it is an easily dimensioned piece like a rectangle or circle it may be easier to create it. I find sometimes to model it myself gives me a better handle of it. Whatever you do, do not get too fancy when creating families as they will slow down your model. Good Luck
Rail Community
