Revit MEP
Active Contributor
bluelion
Message 1 of 7 (1,305 Views)
Importing ang Exporting Schedules to Revit
1305 Views, 6 Replies
07-08-2013 05:28 PM
Is there a way of importing the TXT or XML file back into Revit once changes have been made to the schedule?
ATM I only seem to be able to export my schedules but have no way of brining them back in.
Todd Barry (Mechanical Design Engineer)
Sydney, Australia
Mob: 0438 479 967
E: tbarry@fredon.com.au or toddbarry7@gmail.com
*Expert Elite*
CADastrophe
Message 2 of 7 (1,267 Views)
Re: Importing ang Exporting Schedules to Revit
07-09-2013 05:09 AM in reply to: bluelion
That is correct. Revit's Schedules are a live report of the data gathered from the elements in the Project Model, so you couldn't just be able to import a schedule as a Revit Schedule. If you wanted to bring in an outside schedule, I believe that the best method would be to create the schedule in a .dwg file and then link that into your Revit Project in a Drafting View. An imported OLE object will not come through in Revit.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Active Contributor
bluelion
Message 3 of 7 (1,254 Views)
07-09-2013 01:02 PM in reply to: CADastrophe
thought maybe it would be similar to creating type catalogs.
Oh well I guess its not to be lol
Sydney, Australia
Mob: 0438 479 967
Active Contributor
bluelion
Message 4 of 7 (1,230 Views)
07-09-2013 11:01 PM in reply to: CADastrophe
Once you put the objects in the drawing I though maybe it would be possible to change shared Parameters in a remote spread sheet similar to type catalogs and look up tables I guess.
Whats the issue with not being able to do this?
Sydney, Australia
Mob: 0438 479 967
Member
SashKaz
Message 5 of 7 (1,178 Views)
07-24-2013 07:32 AM in reply to: bluelion
Hi Todd,
There is a way to export your schedule data to a Excel document, make changes within the Excel document, and then pull that data back into Revit. The add-on that you want to look into is Ideate BIMLink.
I have provided a link to the BIMLink website. You should have a look at it and check out some of the Youtube videos as well so that you can see a demonstration of how it works. It is a very powerful program that can save you a lot of time with your schedule edits.
http://www.ideatebimlink.com/
If you have any questions, please let me know. I am more than happy to help!
Sash Kazeminejad
Active Contributor
bluelion
Message 6 of 7 (1,165 Views)
07-24-2013 12:42 PM in reply to: SashKaz
Thanks SashKaz, I will definately look into it. If this wroks you are a legend :smileywink:
Sydney, Australia
Mob: 0438 479 967
Member
SashKaz
Message 7 of 7 (1,153 Views)
07-24-2013 09:36 PM in reply to: bluelion
Todd,
Please let me know if you have any questions. BIMLink is a powerful add-in and works extremely well. The website and Youtube videos will give you a good idea of what it can do.
Sash Kazeminejad
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
