Revit MEP Forum
Import .sat into REVIT
12 REPLIES 12
Message 1 of 13
filipesmsantos
3288 Views, 12 Replies
Hi everyone.
I need to import a .sat file into REVIT. When I do the import CAD and select the .sat format into a Generical Model family appear a message saying some SAT formats lost during import and leave with a empty family file.
I want to know how do you do when you need to import a file with .sat extension.
Thank you
12 REPLIES 12
Message 2 of 13
luseche
in reply to: filipesmsantos
I Had a similar issue, and in many cases I found that it depends how the SAT file was created, in one ocassion was created in Rhino and it was necessary to created the SAT file with the "Optimozed Geometry setting".
I would suggest to try with different exporting options to the SAT file and then tried to opened in Revit.
Good Luck.
Luis
Message 3 of 13
filipesmsantos
in reply to: luseche
One of the main problems is that I am not the creator of the .sat file. A manufacturer of rooftops in this case send us a type of rooftop that we wan´t to use in a particulary case. And, as a Revit designer, I wan´t to make the project with maximum of detail.
But the manufacturer only send us the products in .sat. Unlucky or inexperience by me. I don´t know so I need help here in forum.
But thank you anyway.
Message 4 of 13
luseche
Ok, do you mind posting the SAT file, so I can try it?
Message 5 of 13
filipesmsantos
Give it a try.
And if you can do it tell me how you do it please.
Message 6 of 13
luseche
I opened in the "CAD exchanger App" and then I saved back to SAT format, inserted in Revit as CAD, and it worked,
Please let me know how it worked..
PS: Please do not forget to give Kudos if the solution is satisfactory for you.
Luis
Tags (1)
Message 7 of 13
luseche
Message 8 of 13
filipesmsantos
It works.
Can you explain me again with a little more detail how I can do it by myself.
What is CAD exchanger App and you inserted in REVIT as cad or as .sat?
Message 9 of 13
luseche
Great!
CAD Exchanger is a 3D Data translator.
http://www.cadexchanger.com/download.html
I inserted in Revit as .SAT after I opened and resaved in the CAD Exchanger app.
Luis
Message 10 of 13
filipesmsantos
Excellent.
The only thing that the CAD Exchanger does is a resave of the .sat file?
Cool.
Thank you once again.
Message 11 of 13
piotraschkew
The link provided is broken.  Please provide a new link if possible.
Message 12 of 13
RP-UNG
I'm looking at tutorials online of how to bring in a .SAT file into Revit, so I follow up to the point of going to 'Insert', 'Import CAD', however when on tutorials folk are saying to change the import file type to 'ACIS SAT Files (*.sat), this option is not there at all.
I'm using Revit LT 2016 at the moment, has the .SAT import option been removed in this version as I've noticed all of the tutorials i'm watching are on 2014 and below?
Screenshot attached shows my import options.
Message 13 of 13
koleskey
in reply to: RP-UNG
Did you ever find a solution to this specific problem regarding Revit LT not having the option for a SAT. file?
