When you adopt coordinates from the Revit Arch model, you can then change the orientation of a view from Project North to True North. If applicable, you will see your view re-orient to the new setting. So when it is time to go to analysis, IES/VE for example, which "North" is it picking up? Or do you have to start the IES/VE command from a view that has been oriented?
