need to create a conduit run with bends. all of the standard fittings are loaded into the project. in previous projects i was able to simply create a continuous run of conduit and the bends would show up with no problem. now, i can only draw one straight line conuit and cannot continue.
thanks
You will want to draw using the "Conduit without Fittings" Conduit Type. Before drawing any Conduit, go to "Edit Type", which is located at the top of the Properties Palette. There, you have to assign a default Conduit Fitting for each fitting type that you wish to employ. Just ask if you need any more info!
You may want to check that the conduit type has fittings associated to it
