I am currently a straight CAD Drafter (still learning Revit), and I am in need of a piece of equipment. I am looking for a 10 cubic foot Blender. This item will be used to illustrate how much room is needed to install one or if necessary, how much room it will take inside a Pharm. process room. We also need it to insure the connections are going to be in the right place.
I have seen revit models before that looked great and made me realize that Revit is the future. As things stand right now, I need more schools and access to the program.
So, as I have seen a model before, I now that even a 3-d model would help immensly. Can anyone help?
HD
Solved by CoreyDaun. Go to Solution.
The only place I can think of that might have such a Family would be revitcity.com, and you'll have to sign up in order to download from that site. Otherwise, you'll have to model it yourself as a Specialty Equipment Family. I would suggest not going crazy on the details, unless it's really needed for presentation; it is generally discouraged to detail to extreme degrees in Revit. Another alternative, if applicable, would be to model the blender in Inventor and then import that into a Revit Family.
