Revit MEP Forum
How to show DASH LINES for underslab wiring?
5 REPLIES 5
auto99
4219 Views, 5 Replies
5 REPLIES 5
scritz
in reply to: auto99
create a new wire type called underground, then create a filter for that wire type that will set it to a dash line type of your choice.
jmlarias
in reply to: auto99
You can right click the wire and select "override graphics in view" the line pattern.
You can do it by category, filter or element. after that you just select the color, pattern and others things. I just foud it out by looking for how to make the pattern dashed for underground lines.
Good luck!
TonyVav
in reply to: auto99
You can create a filter to change a line type to dashed for any pipe below grade by using the belo. Cat Very Happy
ttate508
in reply to: jmlarias
Im an electrical designer and by far, this is the simplest solution!
HEETESHC
in reply to: ttate508
Hi @auto99
I hope you doing well.
Are you get your expectable solution? Please notify.
Awaiting.
Don't forget to "Accept As Solution" and "Give Kudos" when an acceptable solution has been given.
