Hi All,
In the family environment I have created a rooftop package unit...
When I want to use selection window to select some model lines in an elevation view everything behind it is also get selected.... To solve this I pick lines one by one which waste a lot of my time....Can some one please show me the correct way of doing this?
Cheers,
M
Solved by ajax05k. Go to Solution.
Non of these work for me mate...
Can't use Tab as they are not connected
I use filter but the problem is there are other model lines on the opposite face that get selected and I don't want them
Is there a way to select things only from active plane?
