Hi There..
I have Problem for seperating the pipeing system to deferant sheet.
I have Created the Coordination Drawing using Revit 2015 when i go to the Plumbing sheet i can see all the pipe in one. i have a Soil, Wast Drain, Vent, Fire fighting system these kinds of pipes i have to add in to my Coordination Work. also We are Going to get the printout for pipe works seperate system by system. i show the HVAC system and plumbing system drawing is coming seperate also i nee to seprate the pipe
here is small veek point from me i dont know how the made the plumbing and hvac system is seperate also Sorry for this if any one can teach me how to do this
Regards
Rafilathif
Solved by L.Maas. Go to Solution.
Most common solution will be to use filters.
You create different views (or copy the views which contains all the pipes.
Then you create different filters to hide the piping not needed in the particular view.
You can filter on, for example, system name or system type.
The Filters button can be found under "view", "filters".
After creating the filters you apply them to the different views by adding the filter to the graphics overrides of the views.
Louis
Please mention Revit version, especially when uploading Revit files.
