I am looking for a macro or instructions on how to make one for:
"Place Duct", then select "Duct Type", and finally select "System Type".
Thanks for any help you can provide.
Jason.
What's wrong with "Create similar" ? 🙂
You may be able to do what you want using a macro program such as Autohotkey.
Otherwise, you may also want to post this in the Revit API Forum.
The default shortcut for creating ducts is DT. I usually use the shortcut or copy/paste similar duct. You can edit system type later on if it isn't what you want it to be.
