My computer has 8 cores. When the Autodesk Revit is running,
the computer shows that only one of the eight cores is processing.
The other seven cores are not being used at that time.
How can I use the other seven cores together to
make the Autodesk Revit run more smoothly and quickly?
My processor model number is Intel(R) Core(TM)i7 CPU 950 @ 3.07GHz 3.07GHz
Looking forward to your soonest reply.
Best regards & Thanks,
Kevin
don't need to post multiple times
answered on your other thread: http://forums.autodesk.com/t5/Autodesk-Revit-Architecture/How-to-make-Autodesk-Revit-run-more-smooth...
DarrenP
