Dear all struggling Revit MEP users,
I believe I have finally figured out how to create a "well connected" piping system, and I wanted to post what I have noticed so that it may help others.
HOW TO MAKE A "WELL CONNECTED" PIPING SYSTEM:
2. Make sure all piping is complete and fully connected, this means there will be a non-zero flow value in all pipes
If these two steps are completed, you will have a "well connected" system. Here's the kicker...Revit may not realize it and still give you problems. The "check piping system" tool may still give you errors. I think this is a fault in the Revit programming, flow information seems to get "stuck".
TO FIX THIS (ONCE THE ABOVE STEPS ARE COMPLETED ONLY!!):
These steps seem to flush the system and cause the proper propigation of flow data throughout the system, and this will fix the errors and create a "well connected" piping system.
There you have it! This is the process I use, and it helps me get all my systems set up for the pressure loss reports. Now go forth and complete your systems!
Post if you have any questions or suggestions!
Sincerely,
Wils02
