Hi
I am new in Revit. I need to know the coordinate of different places in revit document. Also need to check the pipe object end points.
I get an option which shows E and N values. But how do I get coordinate like autocad.
Regards
Naym
Can you use the xyz coordinates in a calculated value? I can only find them in Revit with spot coordinate or BIMLINK, Is there any other way?
Maarten Maarleveld
I don't believe you can obtain the XYZ data from Revit itself though perhaps the ODBC method might work?
Here's a short video showing the pipe coordinate data via Ideate BIMLink, FYI.
http://www.screencast.com/t/n5UOR2D03dfw
Best Regards,
Glynnis Patterson
