Revit MEP Forum
how to edit this
6 REPLIES 6
iamwhatiam1234
325 Views, 6 Replies
how to edit this
hi
see in the attached images how can i move the scale from the information becauase the sheet name is above the scale
how can i move the scale to the other end how can i edit that family
it is a callout
i just done a call out and drag in to the sheet
it will show the sheeno and the scale and the name and number as in the snapshot
i want to move the scale to right side so that i can see clearly
please help
thanks
6 REPLIES 6
L.Maas
in reply to: iamwhatiam1234
When you place it on a sheet it is the view title. The families for this are found as part of the "Annotation symbols" group.
Look for something like the "Anno_View_Title" family. Edit this family and move the sccale label to your  desied position
Louis
Please mention Revit version, especially when uploading Revit files.
iamwhatiam1234
in reply to: L.Maas
i done the editing and added a parametric catogory
but it is not updating the family in the project
L.Maas
I do not understand what you have done exactly.
You edited the "Anno_View_Title" family and added a parameter?
What is that parameter supposed to do?
Maybe you can upload your family so that I can take a look?
What I was talking about is editing the "Anno_View_Title" family and move (manually) the label with the scale to a different position and then reload the family back in into yoor project.
Louis
iamwhatiam1234
in reply to: L.Maas
see i attached the family and the screen shots
before there are three types and i added fourth type as detail title,n
umber and scale(M)
when i load in to the project the forth type i created with (m) is not
showing..
why i created the fourth type is because at some cases i need the scale to
be to the left position
that is the reason why i created fourth type
i added the snapshot please check it
L.Maas
It seems to be working for me. Loaded your family in a project and created aveiw. Placed the view on a sheet.
Selected the viewport. and clicked "Edit Type". Window with "Type Properties " shows up.
Now I can select the different titles under the "Title" entry..
Louis
