As Revit MEP has electrical panel schedule template. When I select the panel, go to ``edit panel schedule’’ tab , want to add the branch circuit description for each circuit, trip, poles, phase, load and others ,but seems the space there in the rows and columns cannot type any letter?
Also When I go to ``manage tab’’—go to ``edit a template’’, try to fill in the branch circuit in each rows and column, the same thing, I cannot type any letter in it?
How to fill each branch circuit description in the panel schedule?
Thanks!
Solved by julianjameson8403. Go to Solution.
Have you looked in the project browser for the panel schedule and tried to add the values through that - providing you have the correct fields in the template to allow that.
Without being rude - could I suggest that you either get some basic training or buy some training manual because the last 4 posts you have left are asking some very fundamental things about Revit that would be covered by training material and the Autodesk Wiki site. By doing this and experimenting on your own - you will find you learn more about the software and how it works.
http://http://wikihelp.autodesk.com/Revit/enu/2012
