Ok so here I am trying to detail an electric room, I have panels transformers and the like right, wellall I want to do is draw a conduit from the connection point with an elbow looking up then place a verticle conduit on the elbow and draw my horizontals to the locations where they belong is there an easy way to do this? when I am placing the conduit the end point elevations are greayed out on the conduit tool menu. Do I have to draw a verticle conduit in an elevation view??? with this software I really shouldnt have to do that it should all be available to me in the plan view.
Pete
Solved by CoreyDaun. Go to Solution.
Hi Pete,
Start the Conduit on the Plan as normal. When entering the second point (which will be directly above/below the first), enter the desired "Offset:" on the options bar and click Apply, and it should create a vertical run.
OK so I tried what you were saying, but when I try to add my second offset right above the first I get a Null symbol, should I be looking at the properties menu when doing this procedure? Because there are 6 areas in the constraints box Horizontal Justification, Vertical Justification, Reference level , Offset, start offset (grayed out) end offset (grayed out) It just seems like I am missing something here and it is probably really basic I have browsed through the help menus and the other available information. I am using Revit MEP 2014 would that be an issue?
Thanks again
Pete
Ok I just had to re read what you stated slowly and try it step by step and it worked thanks I knew it had to be easy.
Thanks again
Pete
I know this is an old post but I'm trying to follow this procedure in Revit 2023 with no success. I'm trying to do exactly what the OP is asking - bring conduits vertically to surface without having to make sections and draw there. Advice appreciated.
Why not use a section if it works? Most of us use a combination of views simultaneously and switch between them as needed.
Funny that the solution does not work for you.
It can be a little bit annoying to have to delete the lowest horizontal segment, but it works quite fine.
Another option, draw a horizontal segment, change the elevation value, and click apply twice.
Fábio Sato
