Can anyone explain to me, how to use custom parameters to create View Group ?
Dear Ammar74,
If you want to add custom parameters for Views group, you have to check the Instance option when adding a project parameter.
Stesp:
1. In Manage tab- -Settings panel- -Project Parameters, add a project parameter
2. Check Instance option, then check Views for the categories. (If you check Type option, Views category will not be available)
See attachment "parameter.jpg", then this parameter will be added in the instance properties for all views in the project.
Thanks.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
