Revit MEP
Active Member
Negaquark
Message 1 of 4 (493 Views)
How to create a variable length LED Luminaire (lighting fixture)
493 Views, 3 Replies
09-12-2012 11:51 AM
 I was trying to make a variable length luminaire that could calculate the load automatically.
The problems I came across were dimensions & watts could not be calculated together, or the message
"Instance Parameters can't be used in Type Parameter formulas.
Type Parameter "Length" is driven by Instance Parameter(s): "Feet"."
First step is to determine the Load per foot. (15W as example)
Family parameter/Type
  • Name: Apparent Load
  • Discipline: Electrical
  • Type of Parameter: Wattage
  • Group parameter under: Electrical Loads
  • Value: 15VA
Next step is to determine the length. (4 foot typical length)
Family parameter/Instance
  • Name: Feet
  • Discipline: Common
  • Type of Parameter: Integer
  • Group parameter under: Dimensions
  • Value:4
  • Name: Length
  • Type of Parameter: Length
  • Value: Feet * 304.8mm (or 1' for imperial)
  • Name: Calculated Load
  • Value: Feet * Apparent Load
Now for the Connector Element
Apparent Load should be Associated to Calculated Load
Label the Length Dimension
This works for a straight line LED luminaire.
For a circle with variable radius & perimeter try this:
Add
  • Name: Radius
  • Type of Parameter: length
  • Value: 304.8mm
  • Name: Angle
  • Type of Parameter: Angle
  • Value: 45
Replace
  • Name: Length
  • Value: Angle / 360° * 2 * 3.14 * Radius
  • Value: Length/1000mm * Apparent Load
 Label the Angle & Radius Dimension
CADastrophe
Message 2 of 4 (483 Views)
Re: How to create a variable length LED Luminaire (lighting fixture)
09-12-2012 12:47 PM in reply to: Negaquark
  • Name: Feet
  • Value:4
  • Name: Length
That error would be occurring because  the parameter "Length", although intended to be an Instance Parameter, is defined as a Type Parameter in the Family.
CADastrophe
Message 3 of 4 (481 Views)
09-12-2012 12:55 PM in reply to: Negaquark
Negaquark wrote:
...The problems I came across were dimensions & watts could not be calculated together...
You can create a formula to directly associate the load with actual length - You just have to make the length unitless:
Total Watts = Watts per Foot * ( Length / 1' - 0" )
Attached is a family basically demonstrates my method, in case it's of any help. (Revit 2012)
Active Member
Negaquark
Message 4 of 4 (475 Views)
09-12-2012 01:21 PM in reply to: CADastrophe
Those were just sample errors I came across while trying to create the luminaire.
This is a "How to thread", not a "Please help me" thread.
I remember reading a post with this type of problem, but could not find it again once I solved it.
