Is there any way to create an Accessory for Round Duct. I have created DA for rectangular ducts with Top, Bottomm Left, Right, Front and Back Reference Planes in the past. But I dont know how to do it for Circular. I tried creating one, but it wouldnt snap to the duct axis.
Also how to control the size of the accessory for the diameter of the host duct.
Really stuck here. Any help is welcome. Thanks in advance
Solved by L.Maas. Go to Solution.
Just have a look at the accessories families available in the Revit libraries
Depending on which libraries you have installed you already can find volume damper families, normally under "Duct\Accessories\Dampers
C:\ProgramData\Autodesk\RVT 2015\Libraries\US Metric\Duct\Accessories\Dampers
Louis
Please mention Revit version, especially when uploading Revit files.
