Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
How to control View Range
3 REPLIES 3
bvm76
445 Views, 3 Replies
I want to show the furnitures on my layout in plan view.
If the top range is set below the ceiling level, you can see the furnitures (can't see any ductwork) but when is set to above ceiling level, the furnitures diappear as if you are inside b/w the U/S of slab and ceiling.
Many thanks in advance.
Please mark Accept as Solution if your question is answered!
Thank You.
3 REPLIES 3
CoreyDaun
in reply to: bvm76
You should have no problems showing both your above-ceiling Ducts and the Furniture on the same Floor Plan.
What Discipline is your View set to?
Is your View a Floor Plan or a Reflected Ceiling Plan?
Could you post a (or some) screenshot(s) showing the View, its Properties, and View Range?
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
bvm76
in reply to: CoreyDaun
Please find attached screenshot.
Thank You.
CoreyDaun
in reply to: bvm76
It looks like your losing some of the interior Walls as well, so it seems that there is something obstructing the visibility of the elements below. Try turning off the Floors Category. If that doesn't work, try setting all Categories to 100% Transparency under Visibility/Graphics Overrides - if the Furniture becomes visible, it means that there are one or more elements in the way that need to be made transparent or turned off.
