I want to show the furnitures on my layout in plan view.
If the top range is set below the ceiling level, you can see the furnitures (can't see any ductwork) but when is set to above ceiling level, the furnitures diappear as if you are inside b/w the U/S of slab and ceiling.
Many thanks in advance.
Solved by CoreyDaun. Go to Solution.
You should have no problems showing both your above-ceiling Ducts and the Furniture on the same Floor Plan.
What Discipline is your View set to?
Is your View a Floor Plan or a Reflected Ceiling Plan?
Could you post a (or some) screenshot(s) showing the View, its Properties, and View Range?
Please find attached screenshot.
It looks like your losing some of the interior Walls as well, so it seems that there is something obstructing the visibility of the elements below. Try turning off the Floors Category. If that doesn't work, try setting all Categories to 100% Transparency under Visibility/Graphics Overrides - if the Furniture becomes visible, it means that there are one or more elements in the way that need to be made transparent or turned off.
