Dear all,
I create conduit drawing from Revit, see picture1 as below, but how to change conduit elbow style as picture2 ?
Lin
Solved by dbutts7. Go to Solution.
take a look at the generic pipe elbow family that comes with Revit - you would need to add tick mark planes, and parameters to control the size of the tick mark, to the conduilt elbow family, if it doesn't already have them (which I'm pretty sure it doesn't). Have you done much family editing, especially related to pipe fittings?
And why would you want to use symbol that indicates a pipe fitting for a conduit? what type of material are using for the bend?
Let me know and I'll provide more info...thanks - db
David A. Butts
Engineering Technology Manager - Gannett Fleming
Autodesk Expert Elite
Revit Certified Professional/Autodesk Certified Instructor
Revit, AutoCAD Architecture, MEP, Plant 3D, BIM Collaborate Pro Subject Matter Expert
