Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
HOW TO CHANGE CIRCUIT REFERENCE
2 REPLIES 2
vsrkk2005
941 Views, 2 Replies
Hi ,
how to change circuit reference in revit mep. i want to make  electrical circuting format like DB1/1L1, DBI/1L2, DB1/1L3. please suggest how to change settings.
siva
2 REPLIES 2
Ahmed.Elmahdy
in reply to: vsrkk2005
what i know you can make circuit's sequence by phase like that A1,B1,C1,A2,B2,C2,A3....etc by clicking on the panel you want, in properties scroll down to electrical circuiting section you will find Circuit Naming is empty just choose "By Phase" from drop down menu next to it, I hope this helps.
Zaatra
you can make a parameter(shared or project ) and name it for example (r,y,b) then make a tag and use this parameter, then when you make a electrical circuit input the value manuly
