Hi ,
how to change circuit reference in revit mep. i want to make electrical circuting format like DB1/1L1, DBI/1L2, DB1/1L3. please suggest how to change settings.
siva
what i know you can make circuit's sequence by phase like that A1,B1,C1,A2,B2,C2,A3....etc by clicking on the panel you want, in properties scroll down to electrical circuiting section you will find Circuit Naming is empty just choose "By Phase" from drop down menu next to it, I hope this helps.
you can make a parameter(shared or project ) and name it for example (r,y,b) then make a tag and use this parameter, then when you make a electrical circuit input the value manuly
