Looking to TAG some duct to show oveall building RL (i.e. height from ground being 0m) instead of EL from related level. Any ideas?
Thanks Ali, your idea is a good one and I have thought of the same thing. Although how do you edit the duct family? It is a system family is there somewhere I can do this?
You cannot edit System Families. If you wish to add a Shared Parameter to them, you must add it as a Project Parameter and apply it to those Categories. This means that a formula cannot be used to determine it's value.
Have you tried using the Spot Elevation Tag? It's located on the Annotate tab. I use this to annotation the mounting height of wall-mounted devices because Revit is not able to include this info in the standard Tag. So, I essentially have two separate Tags for the devices in which I need to label the height.
Hope this helps!
Every time I select the spot tag tool Revit crashes LOL!
Not sure will have to check. Someone has told me not to use that button before.........
