Revit MEP
davebillion
Message 1 of 3 (379 Views)
How can I edit Graphic issues with View Disciplines?
379 Views, 2 Replies
10-31-2012 08:16 AM
I'm working in Revit MEP 2012.  When I have a view's discipline set to Coordination, linked architecture, lighting, and other non-Mechanical elements show as boldly as my duct, piping and mechanical equipment.
When I switch the view's discipline to Mechanical, all non-mechanical items (walls, lights, generic models, etc) fade into the background (half-tone) as desired, but switch to a dashed line.  This happens regardless of Phase (Existing, demolition or new work).  Switching the elements' linetypes in Visibility/Graphics overrides to Solid doesn't fix the problem.
Where do I edit the graphics displays of non-mechanical elements in Mechanical views, non-electrical elements in Electrical views, etc?
CADastrophe
Message 2 of 3 (370 Views)
Re: How can I edit Graphic issues with View Disciplines?
10-31-2012 09:03 AM in reply to: davebillion
You cannot edit the discipline-based visibility alteration, they're set in stone. However, if your out-of-discipline elements are changing to a dashed line, that is a separate issue. Perhaps they are hidden? Could you provide a little more info on the situation, perhaps some images of the View and the View's Properties?
Valued Mentor
julianjameson8403
Message 3 of 3 (288 Views)
11-05-2012 03:52 AM in reply to: CADastrophe
This could potentially also be a view range issue with the beyond linestyle being set to dashed. If the View Depth is set below the bottom cut plane then the beyond linestyle domes into play
If my reply answers your query, please use the Accept as Solution.
Please give Kudos as appropriate to enhance the value of these forums.
Thank you!
