Revit MEP
New Member
engineer12ahmed
Message 1 of 2 (286 Views)
How can i convert Revit to AutoCad with same Colours
286 Views, 1 Replies
10-28-2012 04:12 PM
While you are in the DWG Export dialog selecting views/sheets, click on the "Browse.JPG" button beside the pull-down under "Select Export Setup".
You'll have to create an Export Setup here to get a custom configuration, in which you can assign layer names and colors as desired. Beware, there are a number of limitations, such as element Phasing for example.
CADastrophe
Message 2 of 2 (256 Views)
Re: How can i convert Revit to AutoCad with same Colours
10-29-2012 07:34 AM in reply to: engineer12ahmed
