Revit MEP Forum
How can i convert Revit to AutoCad with same Colours
1 REPLY 1
496 Views, 1 Reply
1 REPLY 1
CoreyDaun
While you are in the DWG Export dialog selecting views/sheets, click on the "Browse.JPG" button beside the pull-down under "Select Export Setup".
You'll have to create an Export Setup here to get a custom configuration, in which you can assign layer names and colors as desired. Beware, there are a number of limitations, such as element Phasing for example.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
