Revit MEP
Revit MEP
0 Kudos
Post 1 of 5
HELP! Face based families hosting at an elevation, not the linked model
554 Views, 4 Replies
05-10-2011 02:42 PM
At the start of the project, placing a receptacle on the wall was easy, just how you normally do it.  Now, we I go to place a receptacle, it automatically has it set for "Host: Not Associated" "Elevation: -92'-0"" "Offset: 0'-0""
How did this happen? How do I get it back to hosting according to the level and the default elevation that it normally works on? Extremely frustrating...
This happened directly after loading a face based receptacle family for floor mounted receptacles.
-crigoli
Active Contributor
0 Kudos
Post 2 of 5
Re: HELP! Face based families hosting at an elevation, not the linked model
02-23-2012 09:33 AM in reply to: crigoli
You made sure that your schedule level was the appropriate level, right?
999 Kudos
Post 3 of 5
02-23-2012 10:02 AM in reply to: crigoli
While you are placing an element, you can change the Elevation value under properties before you actually place it. Revit should make the inputted value the new default elevation.
New Member
0 Kudos
Post 4 of 5
11-16-2012 02:34 PM in reply to: crigoli
I am having this exact trouble, where I can set the elevationbefore I place the receptacle, but when I go to the next floor up, it tries to place the receptacle on the floor below.  As an example, on the first floor (elevation 0'0") I place the device using the 1' 6" default elevation.  When I go to do the same on the second floor (elevation 12' 0") the receptacle Default elevation is now -10' 6" and if I place the receptacle I get the warning that none of the placed item are within this view.  If I then go back to the first floor, the receptacle I placed on the second is in the corresponding location on the first floor.
999 Kudos
Post 5 of 5
11-19-2012 06:39 AM in reply to: wikelly1
You have to 'reset' the default elevation back to the Family's default, which is accomplished by using the Create Similar command.
