You could try printing to pdf. It worked for me. If that's what you're after, try this procedure:
Open a load report --> In the upper left corner, click the purple R (remember they used to call that File...) --> print --> print --> then select a pdf printer, depending on what you have installed it will either be CutePDF, Adobe PDF, or PDF995. Then click print. It will prompt you for a location for where you want the pdf saved.
Hope this helps.
-Tim
