I'm currently trying to evaluate Revit ability to run cooling & heating loads and have run into a couple of problems
I typically use Trace for this
First of all, for background, I have an architectural file linked into an MEP file where I am doing all of my work.
after Inputting all the data for my project, as best as I can tell, and calculating heating and cooling loads
I noticed I was not getting any loads for a few components
If Under heating and Cooling Loads: Building Envelope: Use Function parameter, Revit then sees all of my exterior walls as interior, but I can see all my windows properly.
If Under heating and Cooling Loads: Building Envelope: Identify Exterior Elements, I will then get Exterior Walls but have some, not all, windows that will disappear in the analytic model
So that one selection will give me my exterior wall load but no window load and the other will give me window load but no exterior wall load
If I create an energy model, the analytic model for that appears to be correct, as far as windows and exteriors walls, but this doesn't correct the analytic model for my load calculations apparently
I am also not receiving any partition load and my ceiling space doesn't seem to be transferring load from roof to my rooms, although I don't know how to check this,
Any help would be greatly appreciated
