Revit MEP Forum
Heating and Cooling Loads Error
1 REPLY 1
GHASEM_ARIYANI
6536 Views, 1 Reply
Hi
How do I solve the following warning:
1- Space 2 is not upper bounded by a roof, ceiling or floor element. This can result in incorrect adjacencies and voids in the analytical model. Please ensure that Upper Limit and Limit Offset for Space 2 is set correctly.
2- Plenum 8 has Space Type set to Plenum but has no ceiling surface.  A plenum must be separated from the space it serves by a ceiling.
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
1 REPLY 1
Hi
I found the solution.
After reviewing the different Arrived at the conclusion:
When we Space Tools Use At the top of the room elements such as roof, ceiling or floor  Is placed.
I file architecture No one roof, ceiling or floor I was not draw of the elements.
But then draw ceiling and the MEP Reload this problem was solved.
