I'm having problems with hatching in linked files. I have some hatching in the linked file but even though this linked file is underneath my gen models the hatch is still on top of everything.
For pipes and ducts I can make them transparent but the generic models don't work like that.
The only option I see is to change the view from mechanical to arch but I don't want to do that.
Anyone got any experience with this?
OK thanks for that.
A workaround I found for one family was to create a masking region on the plan view so when it is loaded in it masks out the hatch in the linked file which works well but I have tried to do this for another family and I have done the exact same thing and it just won't work. Any ideas what I might be doing wrong? I have checked everything and both families are practically the same.
Revit thinks that Generic Models is an architectural category. In order to defeat this problem, I believe you will either have to:
1. Change the discipline of the View to Coordination and halftone the link(s).
or
2. Change your elements into Mechanical Equipment, or an equivalently important category.
May I ask why your equipment models are of the Generic Model Category?
