Revit MEP Forum
hatch pattern not not visible in section
1 REPLY 1
harinarayana55
1121 Views, 1 Reply
Hi all
i am assigning a hatch pattern for external insulation in filter. filter was applied in both section and in plan.
my problem is When i am creating a section at middle of the duct the pattern is not visible in section (section 1)
when i am creating a section before the duct the pattern visible (section 2). how could i see pattern even if i place a section at the middle of the duct.
presently i am using filled region in section to replace the missing areas.
i have another problem: please see section 3. when i am placing a section vertically i am able to see the hatch pattern in section. But in my project file i am not able to see the pattern. what may be the problem. I am using revit mep 2014. please see the attached revit file.
thanks in advance
1 REPLY 1
CoreyDaun
in reply to: harinarayana55
Unfortunately, Ducts are not a "cuttable" Category so there is not a visible surface when the Section sliced through the Duct.
