I have been creating BIMs for BURNDY LLC, which manufactures connectors for splicing, tapping, terminating, conducting or grounding. I would like to know the possibility and probability of such connectors to be used in Revit Projects.
Revit has the following system types for Electrical Connectors:
I am unsure as to which of the above mentioned types I should use to classify the Burndy Connectors into. I have attached a few specification sheets of the products that I intend to create in Revit Family Creation.
Solved by CoreyDaun. Go to Solution.
Hello, and welcome to the Discussion Groups!
The Electrical Connector in Revit does not represent a physical connection. Rather, it determine what type of electrical system the element can be connected to in the Project environment. The physical connections are represented by Conduit Connectors.
Thank you for your expert opinion. So, what I infer from your reply is that physical connections can be made only using Conduit Connectors. Burndy Connectors are primarily used for connecting and terminating wires. Therefore, will it find relevance in Revit Projects?
For your reference, I have attached a few images showing how wires are connected using Burndy Connectors.
In Revit, the Wires do not physically exist. Wires are represented by data (in Tags and Schedules) and/or by drawings Wires which are annotations, meaning that they behave very similar to Text, where it exists only in the View in which it was created and does not exist as a model component in the Project. Currently in Revit, even Conduit and Cable Tray do not contain any Wiring information, and are pretty much dumb elements that are created for modeling purposes.
See Revit help for more info on Wiring: Adding Wire
Additionally, that level of detail is typically discouraged in Revit. Modeling down to the screw is not really indented in Revit; that would be more in Inventor's domain. Creating Families with extra fine detailing tremendously bulks up the file sizes, and if tens of thousands of these will exist in a Project... no good. Extremely fine details are best handled by using parametric data rather than actual model elements.
Thank you so much for your valuable response. It was very helpful for me.
