I've read posts about getting rid of an architects color cheme. They say to go to the properties tab for the floor plan and turn the "Color Scheme" option to "<none>". I have done this, and yet the color scheme remains. What am I missing?
Have closed the view and reopend it?
No viewtemplate applied?
It should say: Instance properties --> Color Scheme <none>
Are you sure the view is not shaded?
other wise could you post a screenshot?
I've tried closing and reopening. I've also turned off the view template and as you can see from the screen capture, the colour scheme is set to none.
Are you sure it's a colour scheme? Can you try setting floors to 'No Pattern" in view graphics?
Edit: And it's not a linked view is it?
