Revit MEP Forum
Getting rid of a stubborn color scheme
6 REPLIES 6
Engr4life
401 Views, 6 Replies
I've read posts about getting rid of an architects color cheme. They say to go to the properties tab for the floor plan and turn the "Color Scheme" option to "<none>". I have done this, and yet the color scheme remains. What am I missing?
6 REPLIES 6
daniel.gijsbers
in reply to: Engr4life
Have closed the view and reopend it?
No viewtemplate applied?
It should say: Instance properties --> Color Scheme  <none>
Are you sure the view is not shaded?
other wise could you post a screenshot?
http://danielgijsbers.blogspot.com/
and
http://civil2revit.blogspot.com/
Engr4life
in reply to: daniel.gijsbers
I've tried closing and reopening. I've also turned off the view template and as you can see from the screen capture, the colour scheme is set to none.
troy.wright
Are you sure it's a colour scheme? Can you try setting floors to 'No Pattern" in view graphics?
Edit: And it's not a linked view is it?
Engr4life
in reply to: troy.wright
The problem was resovled when I linked it into a new file.
daniel.gijsbers
More often I see it happen Revit does not update a view.
It's not you I have seen it before
and
Engr4life
Thanks for the words of encouragement haha
