I get the following message when trying to import a .dwg file into Revit:
How do I correct it so I can use the sheet?
Hello, and welcome to the Discussion Groups!
You can try to locate the objects that exist far away from the origin (which may or may not be successful), or you can try Wblock-ing out what you need form the original DWG file, and then link in the new DWG.
