Revit MEP Forum
Gate Valve
2 REPLIES 2
WheelerCJ
904 Views, 2 Replies
Gate Valve
I am trying to insert a gate valve in to my project. I have loaded in the default Revit one and the size only goes to 150mm DIA! I need one that is 500 dia and maybe bigger. I thought the default one would be able to adjust to the pipe size like bends/tees can do. I don't want to have to draw a few different sizes of valves so id there any way I can amend the defualt one or change the look up table to make it bigger?
Also any good sites for downloading material?
2 REPLIES 2
Probably best way would be to create a type catalogue which incorporates the existing values and additional ones, unless you want to use manufacturer specific sizes/dims. If memory serves correctly, pipe accessories aren't related to lookup tables so that option won't work.
This site may be of use
http://www.smartbim.com/SmartBIMObjectFinder/ObjectFinder.aspx#area=2
If my reply answers your query, please use the Accept as Solution.
Please give Kudos as appropriate to enhance the value of these forums.
Thank you!
abulla
in reply to: WheelerCJ
Nibco and Zurn also have some nice gate valve families on Autodesk Seek.
http://seek.autodesk.com/search/gate+valve?source=SearchBox
