Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Flow systems error
1 REPLY 1
tjbeecher
1458 Views, 1 Reply
Flow systems error
I am doing a full flow calculation for a project with there submittals and flow rates.  I am using a Price VAV box.  The owner gave me the submitals on record and made sure that the flow numbers were correct.  The issue I am having is i get the following error
"Elements in HWS 7 are not connected in a single physical network due to one or both of the following: - There are disconnects in the system's physical network. - Elements in the system are connected to more than one physical network."
I have made sure I have caps on any piping that is open.  I have a base mounted pump in the system.  I have double checked that all the VAV's connected.
It has been 3 years since I have done anything with systems.  Any help is greatly appreciated.
T Beecher
Trimble
1 REPLY 1
alan.quinn
in reply to: tjbeecher
Most likely a connector is not set correctly but without the file I have no way of knowing for certain. Is it possible for you to attached the file? I can set up an internal case and create an FTP site if necessary.
Thanks for posting.
