is possible to make a floor plan of two different level?
Example: i will have a floor plan where i see level.1 and level.0 without see the left part of the level.0
The plan i will is indicated in with red line between 0 and 1.
Thank you
BIM Manager - HVAC and Plumbing designer ___________________________________________________________________________
Please use .Accept as Solution and Give Kudos as appropriate to further enhance these forums.
Solved by CoreyDaun. Go to Solution.
Well, technically, the answer would be to use a Plan Region, which allows you to designate an area to which a different View Range will be applied. Unfortunately, this is meant to be an Architectural tool and it tends to have difficulties/problems with Duct and Pipe Fittings. I would say try it out and see if it works for you.
A secondary option would be to create the areas as separate partial Views, and then line them up on the Sheet so that they appear to be a singular View.
