Is it possible to Flip the sweep tee before placing it on the pipe run? I see its going to be placed in the wrong direction but I can't Flip it to go in the opposite direction. Hitting the space bar only switches were the connecting point is, but wont Flip.
Just wondering.
Solved by CoreyDaun. Go to Solution.
I haven't found a way to accomplish this. I was able to get that initial image of the Family (when hovering the cursor over the Pipe) to flip, but it doesn't effect the placement of the Pipe Fitting. I believe that placing and then flipping it afterward is the only way.
