Dear all
am attaching a picture with this question
on the left i connected a diffuser to a duct with flexible
on the left is my drawing, as you can see the connection is like lines | | | | | |
on the right side is another drawing, as you can see it is showing full flexible detail
can this be done ? and how ?
regards
Solved by abulla. Go to Solution.
There's an option in your flex duct properties to change the line style, pick the "Flex" style (once you pick Flex it will remember your selection and default to that).
thanks for the fast answer, it worked
but as another question, as in the pic i uploaded, the view of the flex duct looks narrow and better, when i choose Flex or Flex 2, the looking for the it is not "pretty"
can i chahne the look of the flex or flex 2 view ?
seems to be
as in the pic as it seems the guy used "rectangle" flex duct !!
Looking at the majority of the Flex Duct in the right image, it looks like the Flex Duct Pattern "Flex 2". Note that the appearance of this pattern is affected by the View's scale, so maybe that's making it look strange. The image below depict two differing scale Views of the same section of Flex Duct. Does this seem like the difference you're seeing?
Is it possible to have the same type of appearance show up in section view?
