Revit MEP
Active Contributor
-Marco-
Message 1 of 2 (211 Views)
Flenges on air Ducts
211 Views, 1 Replies
12-06-2013 12:02 AM
i have a problem with air ducts. In Autocad MEP i can select the type of ducts with or without flanges (so i can see in 3D and in 2D the dimensione of duct with flange), in Revit MEP i can't find the selection of connection between air ducts, I will see the flanges of the ducts in the drawing. It's possible?
Example of what i want have...
Thank you.
_____________________________________
Designer 3D: Thermoidraulic and ventilation
AutoCAD Building Design Suite 2015
*Expert Elite*
CADastrophe
Message 2 of 2 (186 Views)
Re: Flenges on air Ducts
12-06-2013 06:37 AM in reply to: -Marco-
I believe that the flanges would have to be separate elements belonging the Duct Fittings Category, specifically with the Part Type: Union. Under the Duct's Type Properties, you can specify that as the preferring Union under Routing Preferences, and you could then use the Split command to divide the Duct segment and the flange will be automatically inserted.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Announcements
Need installation help?
