Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Fitting That Doesn't Give 'Diameter' Box For Changing Size
2 REPLIES 2
Hugh_Compton
451 Views, 2 Replies
Hello
I am trying to create a custom fitting.  I started by using the Metric Generic Template.  In the RVT file attached I have shown my fitting and a pipe.
1) When clicking on the fitting the 'Diameter' field is not displayed.  How can I change the fitting size?
2) When I change the size of the pipe linked to the fitting the fitting doesn't change with the pipe.  How can they be lnked?
2 REPLIES 2
Jrobker
in reply to: Hugh_Compton
It uses the size of the pipe because it's a fitting. They inherit the pipe size because of the parameter use radius.
If you're changing the pipe size you also need to have the fitting selected. So select both and you'll see that you have the radius option.
"It's hardware that makes a machine fast. It's software that makes a fast machine slow."
Hugh_Compton
Thanks! Lots to learn.....
