Hello
I am trying to create a custom fitting. I started by using the Metric Generic Template. In the RVT file attached I have shown my fitting and a pipe.
1) When clicking on the fitting the 'Diameter' field is not displayed. How can I change the fitting size?
2) When I change the size of the pipe linked to the fitting the fitting doesn't change with the pipe. How can they be lnked?
Solved by Jrobker. Go to Solution.
It uses the size of the pipe because it's a fitting. They inherit the pipe size because of the parameter use radius.
If you're changing the pipe size you also need to have the fitting selected. So select both and you'll see that you have the radius option.
