Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
FITTING LOSS COEFFICIENTS - round elbow
3 REPLIES 3
ondrej.uher
391 Views, 3 Replies
As you could see from pictures below I have two identical round elbows. They are from same family, same angle and same dimension. But one elbow has ASHREA tables assign but second doesn't. Why is that?
3 REPLIES 3
salah_2015
in reply to: ondrej.uher
The fitting in pic 4 isn't the one in pic 5 and is both are part of pic 1 can you explain why?
If my answer solved your problem , Please Kudo and Accept as solution.
chris.kershaw
last time I saw this it was the angle it was 45.000001. make sure in the settings that the angle is not set at any angle & its either a hole number increment or a specified angle. delete the bent in question & try again
scott_dakin2
You need to enforce the angles that are found in the Ashrae Tables when modelling or it will not work.
