Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Fire dampers, dampers and other duct accessories.
3 REPLIES 3
revitworkbench
1721 Views, 3 Replies
Does anyone know what the magic is to make a fire damper or other duct accessories auto size? I mean I use the out of the box ones from revit and the are wonderful hover and place into the ducts. Size correctly, everything. I do every thing the same, in other manufacturers models (who dont autosize 😠  and link the duct connections to the duct width/height and drop them in and its like they dont care that you are trying to place them into a duct. What gives? Please help!
3 REPLIES 3
in reply to: revitworkbench
is it possible to post a sample to look at?
jade.l
please check the connector setting first.
jade.l
I believe the trick is to have Height and Width parameters as "instance" parameters. They will then appear with (default) next to them in the list of parameters.
When you link the connector sizes to these parameters they will also then be "instance" sizes.
When you place the item into a duct it should re-size to fit.
