Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Fire Alarm Symbol Plan vs. Ceiling
5 REPLIES 5
bvm76
2505 Views, 5 Replies
Why are my fire alarm sysmbols shown in plan view opposite in ceiling view (please see attached)?
Any suggestion/comments will be much appreciated.
Please mark Accept as Solution if your question is answered!
Thank You.
5 REPLIES 5
CoreyDaun
in reply to: bvm76
Could you attach your Family file? Also, what version of Revit are you using?
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
bvm76
in reply to: CoreyDaun
Hi Corey,
Please see attached family as requested. I am using Revit Version 2013.
Thank You.
CoreyDaun
in reply to: bvm76
In your Family, disable "Maintain Annotation Orientation" - you can find this under Properties with nothing selected OR by going to Family Category and Parameters. This behavior is due to the Reflected Ceiling Plan viewing the object from the opposite direction with Revit trying to maintain the appropriate orientation.
bvm76
Great!
What is the main purpose of this and when to use it?
Thank You.
CoreyDaun
in reply to: bvm76
It's a case-by-case setting - enable it if you need it. I can't immediately think of an example of when I would want to enable this option.
