Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Finding volume of a created Model
3 REPLIES 3
jarrad27
8707 Views, 3 Replies
I created a custom hopper, but would like to find it's volume. It is not a simple shape, as the bottom is an eccentric cone. Is there a way I can have revit give me the volume of my extrusion bend? Thank you in advance for any assistance.
3 REPLIES 3
CoreyDaun
in reply to: jarrad27
You can change your Family's Category to Generic Models and load it into a Project. The Generic Models Category (and probably a couple of others) will display its Volume Under Properties when selected.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
yes, but whay happend this?
Each category has its special needs, they understand that for Duct Fittings, volume is not necessary, if you convert to fabrication parts you will get more fabrication data.
Fábio Sato
